跳转到主内容
Hot iron plug dangerous?
My iron cord/plug heats up so hot, I can't touch it to unplug it.
I am afraid it has been suffering over the years from being unplugged after each use, so that may be a factor.
However I notice that if it is plugged directly in the wall socket in other rooms, it is not hot.
Normal? Dangerous?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
最有帮助的答案
Are you plugging it into an extension cord or directly into the wall?
If plugging into an extension cord, try plugging it directly into the wall outlet and see if it still gets hot, check your power cable and the wiring for the wall outlet.
Using extension cords for appliances that create heat is extremely dangerous - the appliance creates the heat by sending current through something with a high resistance. Which is what will happen when the power flows from the small gauge wire in the extension cord to the higher gauge wire in the iron's power cable!
Regardless - its extremely dangerous and can cause a fire. It needs to be addressed.
这个答案有帮助吗?
得分 2
添加一条评论
That is very dangerous. A potential fire hazard. An appliance that heats should be on as short a cord as possible. Two factors. The longer the cord the the more chance of a hot cord. One of the cords might be too small a gauge, causing too much resistance resulting in hot wire.
这个答案有帮助吗?
得分 2
添加一条评论
Agree with all that has been said. The most likely cause is that the cord had been removed in the past by pulling on the cord instead of the plug. This has probably cause breakage of wiring strands. You can find a replacement plug and cut off the existing one (naturally when not plugged in) a few inches back from the plug. Install the replacement and see if this fixed the issue. Do not continue to use it as it is now.
Ron
这个答案有帮助吗?
得分 1
添加一条评论
The iron is plugged into a heavy duty surge protector along with a lamp cord which is not even warm!
这个答案有帮助吗?
得分 0
添加一条评论
I think that pulling on the cord is the culprit..gotta break bad habits. Not taking chances and bought the same. Thanks to ALL
这个答案有帮助吗?
得分 0
添加一条评论
Clothes irons draw a lot of current. If you're experiencing this hot plug at only the one outlet, the outlet is bad. Chances are that the contacts in that outlet are not squeezing as tight around the iron plug prongs. If that's the case some arcing is taking place, causing the heat you're feeling on the plug. Fix? just replace that outlet with a NEW ONE.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ccheryld 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 94
总计 11,037
