跳转到主内容
The Dell Inspiron 15 (N5050) is a mid-sized laptop manufactured by Dell, Inc. that operates on Windows 7. The laptop features include a WLED HD display screen and a max supported memory of 8 GB.
34 个问题 查看全部
How do I reboot my Dell Inspiron N5050 laptop without the reboot disk?
I turned on my computer this morning and it didn't go to the same screen. I really can't explain it. My screen read, "Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key". I've Googled the situation, and it says to hit F8 several times before my Dell screen comes on. I've done that several times and it hasn't helped at all. I don't have the disk that reboots my laptop, and I just bought this laptop three days ago. Can somebody out there please give me some simple directions on how to fix this? Thank you in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Did you buy this computer used? If the Laptop is still running Windows 7 and you just purchased it a few days ago, you should call the store you purchased it from. There is something wrong with the Operating System that was installed on the Device. It was most likely an illegitimate copy if the laptop was purchased Used. To reinstall the Operating System if you cannot perform a system recovery through the "Blue Screen" options, you will need to have a USB or Disk that has a new Operating System on it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carrie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 1,686
