跳转到主内容
An Amazon tablet released in 2014 featuring a 7 inch HD color touchscreen display.
33 个问题 查看全部
Where can I find the IMEI or MEID number
I have an Amazon Fire HD 7 (4th GEN) tablet and I cannot locate either of these 2 numbers. Specifically, I'm wanting to use my fire to accept square payments but the more research I do the more I'm learning this may not be possible.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You find the cereal number by going into settings under device find device options and click on it your serial number will be at the bottom hope this helps
完成的
添加一条评论
3个答案
已选择的解决方案
  1. To view the SIM, IMEI, and Serial Number, from any screen, swipe down from the notification bar.
  2. Tap Wireless.
  3. Tap Mobile Network.
  4. Tap Advanced Network Settings.
  5. IMEI and SIM Serial Number will be displayed.
  6. To view the device Serial Number, from any screen, swipe down from the notification bar.
  7. Tap Settings.
  8. Tap Device Options.
  9. The device Serial Number will be displayed.
这个答案有帮助吗?
得分 3
2条评论:
Thanks for your response. I actually have to tap on settings on my noifications bar and then I am able to tap on Wireless. When I tap wireless I only have 4 options:
Wi-Fi
Bluetooth
Location-Based Services
Airplane Mode
Is my tablet missing information? Should I do a reset to factory defaults? I don't want to have to do this but will if I thought it would fix this issue.
完成的
Is there a "More" area you can tap on? If so, try that to be taken into your Settings then located and tap on "Wireless & Networks"
完成的
添加一条评论
Simply type code *#06#
这个答案有帮助吗?
得分 0
2条评论:
Type it where, if the tablet is your only working device?? I also am with Brenda Smith. Mine only have the same options.
完成的
On dial pad of iPhone brother.
完成的
添加一条评论
You can find your serial number by going into settings under device click on device options and scroll down to the bottom your serial number will be there hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brenda Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 61
总计 20,848
