跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
How difficult is it to replace wifi ic?
Picked up an iPhone 6 on the cheap ($60) with greyed out wifi. Because there's not a massive risk in the price, do you think it'd be possible to replace the Wifi IC successfully or is it a difficult task that I should let a specialist do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I guess if you have to ask the question, then yes, it is too difficult for you to do :>).
This is by no means an easy repair unless you have the proper tools and some experience working at this scale. It certainly shouldn't be the first thing you try. There are plenty of videos on youtube that make it look easy but these folks are generally using multi-thousand dollar micro-soldering workstations under stereoscopic magnification.
Do you have a hot air station (not a heat gun)? Are you experienced in removing micro-BGA IC's from densely packed iDevice logic boards?
If you don't feel comfortable doing this yourself, then look for a repair shop that does micro-soldering repairs. It shouldn't be a very expensive repair.
这个答案有帮助吗?
得分 2
1条评论:
@refectio thanks! I'm pretty new to repairs and completed nothing close to a wifi IC, I guess I'll stay away from it then haha
完成的
添加一条评论
添加你的答案
Matt Howard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 1,410
