跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 个问题 查看全部
No touch with broken glass. No touch after repair.
Ipad Air 2 with broken digitizer and no touch. LCD was working without issue. New digitizer installed and unit still does not recognize touch. I have installed 2 known working digitizers and still no touch. There is no physical damage to the cables or pins. Requested an estimate from IpadRehab in regards to this issue and it is something they do not offer for repair. Any body have any ideas what my next step may be?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The iPad Air 2 has a different Touch configuration than what is well understood on iPhones (esp. the iPhone 6P). I haven't come across your specific problem but looking at the schematics, the Touch is controlled by two Cumulus IC's and one Stinger IC. That's a lot of silicon and traces that can go wrong :>).
This would be a rabbit hole type of repair and I can understand why many shops wouldn't want to quote you a price. No Fix/ No Fee works well when you have solutions and easy access to parts. At 30$ a pop plus shipping for a Stinger IC and an unknown and undocumented problem, any repair attempt here would have to be on a parts+a minimum labor amount approach.
You need to speak with your customer to see what kind of appetite they have for this repair. There is no easy fix.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Tony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 120
