跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
WiFi still greyed out after replacing antenna - Next steps?
So I replaced the WiFi diversity antenna after following the iFixit guide and it seemed to have gone well apart from the Wifi is still greyed out and the bluetooth still doesn't work. Please help, many thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I think you would need to contact a logic board repair service as the Bluetooth and Wi-Fi are on the same IC.
What country are you in?
这个答案有帮助吗?
得分 2
5条评论:
@gigabit87898 is most likely correct on board repair. Sounds like your wifi ic needs replaced or reballed. That has been the only reason I have found so far for greyed out wifi.
There are components surrounding WiFi ic to check as well, but either way would require Micro Soldering repair.
Check out this video: https://youtu.be/S91fukLKZcU
完成的
Thanks for the help @teetopp
完成的
@gigabit87898 @teetopp Think it's more than likely the wifi IC. I'm not specialist with these but do you think it'd be possible to replace this IC if I buy a new one as well as flux and a heat gun? Or is it a hard procedure that I should avoid
完成的
Personally, I would recommend a professional Micro Soldering Tech to do it. There are several things that could go wrong for a beginner from overheating, Tearing pads, knocking off other components, etc...
And... it may not be the Wifi IC, it could be one of the components on that circuit and a professional would be able to diagnose that before changing the IC.
You can look for local repair shops, call them and price it, or even look through the PRO ads here on Ifixit and find one that you could do a mail in repair :)
完成的
I agree with @teetopp. This is not the kind of thing you want to learn with when you still value your phone. If you want to do it yourself, buy a bunch of dead phones and practice, practice practice. Then try it again on a working phone before ever touching your own device.
完成的
添加一条评论
添加你的答案
Matt Howard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 200
