跳转到主内容
Android's 4.4 OS with a 1600 x 2560 pixel resolution.
45 个问题 查看全部
Green lines appear quickly and device restart
I had this problem a while ago and i live with it. Problem some and dissappear.
You can watch the video link.
I chanhe the software and the same problem appeared. I install the stock Rom and problem did not disappear. I tried other Android roms and same problem. Most of the time problem appeard when battery is low. Most of the time when problem happens my device restart.
https://youtu.be/mKiJAvxAnc0
Samsung galaxy tab s 8.4 lte
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What is possible fix for this?
完成的
添加一条评论
1个答案
Your batery may not be providing enough voltage. Try plugging it into a wall charger, with the battery out. Does it do the same?
Edit: I dont see the restart happening.
这个答案有帮助吗?
得分 0
2条评论:
Before i record the video device restarted twice(sometimes it doesn't restart) . As well as for plugin the charger i can't tell now, i will check more than once. Also how can i be sure if the battery does not provide enough voltage?
完成的
use a multimeter if you have one, if not then try something else
完成的
添加一条评论
添加你的答案
Teto Cv 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 6
总计 314
