跳转到主内容
How to replace keyboard
Hi,
Is it possible to replace the keyboard from my macbook pro from qwerty to azerty?
And does anyone know if I can use the keyboard from my older A1278 (macbook unibody 13" late 2008) or do I have to buy a new one?
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You don't need to replace the keyboard, only carefully lift the key caps and then re-align them to the altered pattern.
Here is a vid on doing this: How to remove and clean Macbook Pro keyboard keys that is if you want a permanent setup. Or, use a cover like this one: French (AZERTY) Keyboard Cover which is what we do.
Now the fun part! You'll need to find the needed keyboard layout driver for the other keyboard pattern or create your own. Here is how you can get to the Apple supplied layout drivers: How to change the keyboard language in OS X
这个答案有帮助吗?
得分 2
2条评论:
Your Keyboard Cover link is broken, might wanna verify it’s the correct link. :-)
完成的
@tronke - Keep in mind this post was over 2 years ago! I don't control their web site. Here's the current listing: https://kbcovers.com/french-azerty-keybo...
完成的
添加一条评论
MacBook Pro 13" Unibody 中期 2010 键盘更换
that works!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Erwin Cornelis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 856
