跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 个问题 查看全部
MacBook wont start unless connected to charger
Hi,
I have a Macbook Air 13 2011 which wont turn on unless connected to the charger. After starting I can safely disconnect the charger and the battery takes over but I can not start from battery alone. Already tried a different battery.
I spilled coffee over the keyboard 2 years ago and didn't touch it since then.
Thank you very much for any suggestions.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Needs new power supply
完成的
添加一条评论
1个答案
最有帮助的答案
Hi R P
Its sounds like you might have damaged the power circuitry. Does the power LED light detect that the battery has a charge when it is not plugged into a power source? Does the computer sleep on battery power or turn off completely when you unplug it?
If you did damage the power circuit you can run a hardware test to see if it detects any problems.
https://support.apple.com/en-us/HT201257
The main power circuit is integrated into the motherboard so keep in mind there is not a lot of options for replacing it.
这个答案有帮助吗?
得分 1
2条评论:
Hi, thank you for your reply. What do you mean by power LED light? The green dots to check the charge of the battery? I have a MacBook Air which does not have that feature.
When I unplug the MacBook it does not shut down but runs normally with battery power. Also the battery charges. The problem is I cannot start from battery alone. For that I have to plug it in.
完成的
Sorry about that many laptops have LED indicator lights that show if your battery is detected when it is in sleep mode or turned off... I found a apple thread with a similar issue on a Macbook air that might help you?
https://discussions.apple.com/thread/511...
完成的
添加一条评论
添加你的答案
R P 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 153
