跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
6s plus No boot
I got a 6s plus that came in dead, aftermarket battery. Connecting to charger pulls 0.4A but no boot. Connecting to DC power supply no amps pulled and it will not boot either (it actually pulls 0.02A before promt to boot but I tried it on my own, known good working 6s+ and it does the same)
I thought half an amp is wrong, it should be 1A so I replaced tristar with a new one but still doing the same.
All power voltages I could think of are present. No water or physical damage I could see.
Any clues?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
How are things looking on VCC_Main?
完成的
All voltages I measured are there: vcc main, nand, tristar and around pmic power rails are there. Couldn't find any shorts whatsoever
完成的
添加一条评论
1个答案
已选择的解决方案
First things first...does iTunes recognize your device if you plug it into the computer? We need to eliminate the possibility of a bad BL or LCM driver. You may have already checked that but we don't know based on your comments.
Assuming the BL/LCM circuit is good (as is the screen), the have you checked ALL of the PMIC output voltages (there are 28 of them)? Start with the main ones like CPU/GPU/SOC/FIXED/SDRAM/SRAM/PP1V1. TRISTAR requires the presence of PP1V8_SDRAM. No need to enumerate them, just tell us which ones, if any, are out of spec or not present.
这个答案有帮助吗?
得分 4
3条评论:
I did try to plug it to itunes, it doesn't recognize it. Screen is good, tried it on my own 6s+ and it worked just fine. Current draw on DC power supply shows virtually no amps, so it's not trying to boot. I'll have to make a checklist of the power rails, but all that I measured were present. Will report back if and when I find anything suspicious
完成的
Any update on this problem i have one with same issue.
完成的
No luck Tim, the client wanted it back so I lost this was a no fix. Too bad, I really wanted to solve it
完成的
添加一条评论
添加你的答案
Rodrigo Maero 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 1,130
