跳转到主内容
加入维修社区 - 创建账户
Repair guides for cell phones manufactured by Micromax.
Phone isn't charging beyond 85%.
I have a Micromax YU Yunicorn, it doesn't charge after 85%. Initially it didn't charge after 98% then 88% then 85% .
Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Discharge your phone completely — run it down until it shuts off. Then charge it up as far as it will go, and discharge it one more time.
Hopefully this will calibrate the battery to register its capacity properly. If it doesn't, then you'll need to replace the battery.
这个答案有帮助吗?
得分 1
4条评论:
Actually I tried resetting my phone but each time the % comes down more. I took my phone to the service center, they flashed it and it became normal but the issue arose after a few weeks.
Thanks for helping me out. Are there any risks involved??
完成的
No, the battery is a normal service item. You need to replace it every year or two. Just get a new one!
完成的
Errrr.. it's a non removable one....
完成的
I haven't opened that phone, but most batteries are replaceable even if the manufacturer doesn't recommend it. Try taking it apart — you might surprise yourself with your skills.
完成的
添加一条评论
添加你的答案
Sarath Chandra 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 733
