跳转到主内容
The latest phone in the HTC One line, simply called the HTC 10, released in 2016.
Can I only change digitizer and not the LCD?
Can I only change digitizer and not the LCD? My screen top layer is broken, the digitizer and lcd are fine, I don't think there's any way to change the top glass without changing digitizer and touch screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You can cgange just the glass but this is not easy. In fact if you have never done this repaor before you are probably better off replacing the lcd. You can try to replace the glass but you will probably end up causing damage to the lcd therefore you you might have to get a new lcd after the glass replacement.
这个答案有帮助吗?
得分 1
2条评论:
Thank you for this reply! I am in the same boat -glass is scratched but the screen is fine. Wondering if I should replace just the glass (digitizer) or do a combo with the screen. What makes the digitizer only replacement so difficult? I've only done screen replacements before, not digitizers.
完成的
Thanks @harisahmed123 . I'd like to try this (i.e. replace digitizer only and not the whole assembly with LCD panel). LCP panel is fine (I can still use the phone) but screen cracked.
All videos I see on the HTC 10 are to replace the whole LCD assembly. You know of any video showing the digitizer replacement?
完成的
添加一条评论
添加你的答案
Mahdi Mohammadi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 787
