跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Touch Display does not work correctly
The upper 1/3 part of the touchscreen is very laggy and pretty much useless, and nearly every 20-60 seconds it acts like i touched anywhere on the screen. It can get really annoying! :/
PS: I have never seen the inside of an iPhone and i never tried to open it in any way!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Sounds to me like the digitizer needs replacement. Unfortunately, that is a rather difficult job so unless you want to hand your device in to a repair shop I recommend you buy an already assembled fixtureboard+digitizer+homebutton. I have made good experiences with that, got mine on eBay for 32$ here:
http://cgi.ebay.de/APPLE-IPHONE-3G-TOUCH...
Doing the job yourself is easy. Follow the step-by-step guide on ifixit and use the old LCD with the new digitizer/lens. You'll figure it out!
Before doing this, i'd check out the connector 2 and see if it's damaged, so you won't be out 30 bucks in case it's not the digitizer that's faulty.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
baboehne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,321
