跳转到主内容
捷威所制造的台式机的支持界面。 现在捷威被宏碁的子公司,现在捷威所有新的产品都是宏碁公司旗下的产品。
40 个问题 查看全部
DVD drive has been corrupted and no longer works
I just purchased this Gateway dx series desk top computer and was downloading information disk for my printer and external hard drives . Everything was going great until I downloaded my kodak camera disk . When I restarted my computer the information from Kodak came up in about 4 different windows . After closing the windows I tried installing my printer disk and got no response at all. I checked my "hardware" and the DVD rom drive was no longer registering on my computer. I ran a systems check and it said ; 'DVD rom drive has been corrupted' . I tried to get it back on by using the recovery disk but I got no response . I tried down loading the hard drive recovery but nothing happened ...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I sounds like a registry problem with the drive filters. Thankfully Microsoft has provided a simple solution to this problem that requires you have .Net Framework 2.0(Obtained from Microsoft updates). If you already have that, then simply download the Automated Tool from Microsoft. It should scan and fix any problems you may have with your CD drive. If it still does not work you can fix it manually by going here to see the manual way of fixing it.
这个答案有帮助吗?
得分 1
2条评论:
Thank You Joel , I first ran a "Norton scan" to clean out any virus . Then I went to the Microsoft updates you recommended . I downloaded the first thing I seen that said anything related to DVD Drives. I got the DVD icon back on my computer . I put a disk in and 'waa laa' , it played . Once again , Thank You very much for all your help ...
完成的
Thats great--now will you mark his answer as accepted to clear the question. Thanks +
完成的
添加一条评论
添加你的答案
Duval Clemmons 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,244
