跳转到主内容
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210 个问题 查看全部
Are Apple Watches repairable?
Hi. I have tried researching into this and I have found mixed answers. From what I can see, by replacing just the digitizer (glass) the touch will not work because of an IC chip. But if I were to buy the lcd and digitizer assembly, it should work with no problem. I have a lady asking me if I can replace screens on Apple Watches and it is something I would like to be able to offer, since I am having more demand on fixing them. Though I know parts can be expensive and it is best to avoid eBay and Amazon for parts, it is something that I would like to know how to do if possible. So if a few people can clearify this and all, that would be greatly appreciated. Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
已选择的解决方案
Good question!
Let me answer it this way: Fixing the steps of your home is something many of us can do. Fixing a computer takes some deeper skills, and fixing an iPhone or iPad takes even deeper skills.
So fixing an Apple Watch while repairable, takes even more skills!
The real question here is it worth the cost of learning and getting the needed tools and parts to offer the repairs? Are you skilled enough?
Even in medicine we have more doctors skilled in chest and abdomen aliments than brain surgery.
Are you able to get enough business to make it pay?
这个答案有帮助吗?
得分 4
3条评论:
Good point. I think the other issue is the cost of parts, and therefore the total cost of repair, versus the value of the watch.
完成的
Thanks for the response. I do understand there is not a lot of demand and prices can be high but I do have some demand. I think it would be something to order the part when one is needed and all. But my main thing is I'm wondering if a lcd and digitizer assembly would actually work on an Apple Watch if I were to replace that? I have seen mixed answers on that and I'm not sure if it is or not because of that.
完成的
Most of the issue I think is skills & the proper tools. Just like fixing iPhones & iPads some people have the knack for it others don't. Or are just don't use care damaging things in the process.
The best thing here is to find a broken one and see if you can fix it.
Even still you do need to know how to evaluate what is damaged before digging in with a customers watch, and you may end up buy them a replacement.
As not many people are attempting servicing the watch yet (many are still under warranty) you are a bit of a trail blazer here.
完成的
添加一条评论
Yes Apple has an out of warranty repair program. Usually less ~ $50 the price of a new watch.
https://support.apple.com/watch/repair/s...
这个答案有帮助吗?
得分 1
添加一条评论
I love how no one is friggin answering this guys question.
He wants to know if replacing the actual LCD assembly WILL WORK, as opposed to the glass only repair which will not work because of the IC chip serial issue.
I'm also wondering myself, so if someone can actually answer the question that'll be great!
How is this the top answer?
这个答案有帮助吗?
得分 0
1条评论:
@justinr - So how many Apple Watches have you fixed? I bet you I've fixed just as many ;-} Thats the problem no one knows how to fix them! Apple is still the primary repair source as they are still under warranty on the most part.
We're all groping in the dark here.
完成的
添加一条评论
are they fixable, yes they are. however fixing them isnt the only issue. the bigger issues is cost. unless you know what your doing and fix it yourself then the parts and labor involved fixing them normally cost the same as buying another watch. its cheaper to apple fix them or buy a new one then deal with the aftermarket parts and the seals that may hold.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carlos Ramirez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 48
总计 3,351
