跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
iPhone won't turn on at all and doesn't even show the battery symbol
I dropped my phone yesterday and the screen just went black, I was on a call at the time but the call carried on I could still hear my friend, it was illuminated so the screen came on it was just pure black and I couldn't go to the home screen or turn it off or anything, in the end I just hard reset it using the home and power button but then I wouldn't come on at all wouldn't show that it was charging or low battery anything. Really need some help with this as I've tried changing the battery and checked to see the display was connected properly but it was all perfectly fine, I have no idea what the problem is.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
It sounds like either the screen has died or the LCD driver circuit on the logic board is damaged from the fall.
If you haven't already tried (I'm a few days late here), I would suggest installing a replacement screen. Preferably something that is known-good or bought from a reputable supplier as you are trying to eliminate a variable here. If a known-good screen doesn't work, then you have a logic board issue and that will require a micro-soldering repair.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Michael Gaffney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 146
