跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Can I backup data files from a bootable HD to another MBP?
I need to backup data files on a hard drive from a non-working 13" mid 2012 MBP (bad logic bd and not sure of OS) to my working 15" MBP late 2011 (El Capitan).
I'm assuming if my MBP is running and I plug in the HD (using iFixit adapter cable kit) it will be recognized as a external storage device.
Any suggestions / warnings before attempting this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
what kind of backup you want to do?
If your disk works fine you can boot externaly with your MBP 15: connect the 13'' hdd via usb power on and push Alt on the keyboard , there you will have the boot options for the diferents drives, log in the 13 and you can do a full back up, Time machine or other type.
other way is just start your 15" connect the 13" hdd via usb and you will see it like a external drive and you can copy everything from it
这个答案有帮助吗?
得分 1
1条评论:
thanks for the great suggestion. not sure how you were the "chosen solution" vs "most helpful answer" but appreciate your time to answer. I just need to copy my daughters data files, mostly pics and some docs off the HD before it goes to Apple for warr. covered logic board repairs.
完成的
添加一条评论
最有帮助的答案
Just to be clear we are talking about the non-retina model here which is struggling (has a 2.5" SATA drive).
There is two ways you can transfer your data:
  • If the system can be booted up in Target Disk Mode you can treat it like an external drive.
  • If the system just won't start you'll need to pull the drive and connect it to a SATA to USB adapter. The IFIXIT adapter will be just fine.
Once you can physically access the drive the best way is to leverage Apples' Migration Assistant app.
Here's the Apple T/N's & other info that explain things:
这个答案有帮助吗?
得分 3
1条评论:
thanks for the great suggestions, appreciate your time to answer. Non retina, not sure of drive yet, need to open it up still. I just need to copy my daughters data files, mostly pics and some docs off the HD before it goes to Apple for warr. covered logic board repairs.
完成的
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 66
