跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for iRulu tablets.
Why is my device not powering up?
my device is not powering up. I suspect its because my kids have exhausted the memory space. the device just turns as if it wants to open but it does not open. please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
3条评论
I have the Irulu SpiritBook S1L and I haven’t used it in about 1 1/2 years. Every time I power it on it just goes to a black screen. How do I fix that?
完成的
My irulu won't charge. Could it be the battery and how do I fix it?
完成的
Someone dropped my irulu tablet, and became black.
完成的
添加一条评论
1个答案
已选择的解决方案
I'm not sure why it wouldn't boot up, but yiu may be able to enter recovery mode...
Recovery Mode options vary for each Android device and can be different even on devices from the same manufacturer. Depending on your model of iRULU tablet, you may need to try other combinations, which include:
Home button + Volume Down button + Power button
Power button + Volume Down button
Power button + Home button + Volume Up button
Power button + Volume Up button
Power button + Volume Up button + Volume Down button
Follow the steps provided below to perform a Hard Reset on your iRULU Android Tablet:
Turn your iRULU tablet off.
2
Press and hold the correct key combination to boot your Android tablet into Recovery Mode.
3
Release the power buttons once your screen turns on and the device vibrates.
Keep holding the other buttons for 10 seconds.
4
Your Tablet should now boot into Recovery Mode.
5
Scroll down to the 'Factory Reset' option using the volume down key.
6
Select the 'Factory reset' option by pressing the power button.
7
Now your Tablet will start the hard resetting process.
8
Keep in mind that once the process begins don't press any buttons and don't try to turn the device off.
9
Your tablet should now be reset
这个答案有帮助吗?
得分 4
3条评论:
Micheal, thank you. It finally worked. After being on my shelf for 2 years. I couldn't find anything that would help, until I came across this post. Thanks again.
完成的
but my irulu tab is windows 8
完成的
sir
iRULU WalknBook how can windos format
boot key?
完成的
添加一条评论
添加你的答案
John Olaoluwa 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 29
总计 5,109
