跳转到主内容
The X5 Max Pro is a low-end slate Android smartphone released by Doogee in June 2016. This device has no readily available model number.
3 个问题 查看全部
Ghost touch while playing MOBA games (Mobile Legends)
While I am playing Mobile Legends, I experience ghost touch in which I the touch point is bit far from from where I am touching. I played different MOBA games and the same issue I experience. Any help is accepted.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
Umm I also play mobile Legends but you can go and you will see a gamemode you recently played ,the chests, events and the shop then you will see at the top a person with headphones press it and you type your problem and then the person will help you.
这个答案有帮助吗?
得分 0
添加一条评论
Try replacing the digitizer.
这个答案有帮助吗?
得分 0
添加一条评论
Cara memakai cit gimana
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Elmer Fang 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 17
总计 451
