跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
Why won't my iPhone turn on after battery drain?
So, weeks before this happened, I had my battery newly replaced. The replacement was doing fine, I was having no problems with it.
Until 2 weeks ago, I forgot to charge my powerbank and my phone drained all the way to 0%. I was thinking that I would just charge it when I got home, but that was not the case. When I plugged the phone in, it just wouldn't open. It wouldn't charge. Nothing happened. I charged it for the whole night, and there was no sign of life. I even tried charged it for a whole day.
When I tried connecting the phone to my laptop, iTunes/my computer wouldn't detect anything. It seemed like my phone suddenly turned into a brick.
I tried almost all the tricks: Holding the power + home button at once for seconds, connecting the phone to the computer, attempting DFU restore mode, etc. Nothing would work. I even tried using a blow dryer but it would not switch on.
I did not drop the phone. It was in my pocket the whole time. Plus, while charging, the phone doesn't heat up or anything.
P.S. This has happened to the same phone before. Only before, when I connected it to my laptop, it detected the phone and it even went to DFU mode. The issue got fixed after I got a battery replacement (not the same battery as this).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Now I'm not 100% certain, but to me it sounds like MOBO (motherboard issue).
In with case I actually would recommend getting another phone. fixing the issue is probably doable but would take a lot of time and money+ special skills to be done (micro soldering).
完成的
添加一条评论
2个答案
You Need Change this ic
No Way without this ic .
这个答案有帮助吗?
得分 0
添加一条评论
check to port to see if yousee any thing in the port. use compressed air if you do to try and remove it. it there is something there and the air doesn't remove it. then try a plastic pick tool and remove it. becarefull not to damage the port. If there is nothing in the port try holding the power button and home button for 3 seconds. Another thing to try after holding both the power button and the home button down at the same time for 5 seconds is to hold the power button for 3 seconds then while holding the power button down press the home button and wait for 3 to 5 seconds to see if the battery logo. If this does not work then it will most likely need some sort of repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michaela Balagapo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 93
