跳转到主内容
Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
Why am I getting a "no service" flag?
I used it all day yesterday (in the field) just fine, and all my other iDevices seem to have cellular connectivity here at home, so why all of a sudden am I getting this fault (and yes, I turned off the wifi and it has no connection)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Dear one, It could be a SIM failure issue. Reset the network settings on the iPad and see if there will be service coming up. If there is still no service i'd suggest testing the SIM in another device just to confirm and get a SIM replacement done....when you done this then ping me on the same.....thanks
这个答案有帮助吗?
得分 0
3条评论:
Raichel,
"Dear one?" Anyway, I shut the iPad off, pulled the SIM card (it looked normal), and reinstalled it. When I turned the iPad back on it worked fine. I know this doesn't help your troubleshooting knowledge database, but it solved my problem (at least for now). If this happens again I may try your process, but how do I "reset the network settings"?
Thanks "cutie"
完成的
Dear Tom,
you can go to this way and reset your network settings:-
1. From the Home screen, tap Settings.
2. Scroll to and tap General.
3. Scroll to and tap Reset.
4. Tap Reset Network Settings.
5. Tap Reset to confirm.
完成的
It worked.. thankyou raichal
完成的
添加一条评论
添加你的答案
Tom Manson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,012
