跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Touchscreen no longer working
Hi. I have just fitted a new display assembly on my iPhone 6 plus following the guide on here but when i turned it back on it shows the lock screen but wont let me swipe or type in pass code anybody got any ideas or could it be a faulty display assembly?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Was the damaged screen working? Did it have touch? If it was, reconnect it to make sure it still works to eliminate the new screen as not working. Also, did you make sure to put the same screws back in the shield in their same spots? It could be several things...Bad LCD, connectors not lined up when putting them on, Long screw damage, or just a case of touch disease
完成的
im very careful with the layout of the screws so all screws are from where they were located before and yeah the damaged one was working
完成的
try the damaged one again if you still have it...if it works and you are sure that the new one is connected correctly...then I'm pretty sure its just a defective screen
完成的
i took the new screen off and there was a tiny piece of plastic in the connector preventing it to seat 100% Thanks anyway
完成的
添加一条评论
2个答案
已选择的解决方案
Got it working now took the screen back off to find a tiny piece of plastic preventing a connector from seating 100% Thanks for your help :)
这个答案有帮助吗?
得分 0
添加一条评论
It possibly could be a faulty display or connectors. Have you made sure the connectors were all seated properly? Sometimes if a single pin is out of place it could not work. Are there any lines or blurs in the screen?
这个答案有帮助吗?
得分 0
1条评论:
im sure they are seated properly from the little click when you push them into place and no lines on the screen also everything was working fine before replacing the display and i am extremely careful when removing connectors
完成的
添加一条评论
添加你的答案
Darren McIntosh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 67
