跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
How remove horizontal line(s) at bottom, after replacing screen?
Just replaced the screen/display-assembly on my iPhone 5s, using these iFixit guides:
iPhone 5s 显示屏更换
iPhone 5s LCD及数字转换器更换教程
Thankfully, it powers up; the home-button works; and the display (*mostly*) works, also, but with this one, minor flaw:
At the bottom of the screen, there are several lines that show up in the "dock," towards the very, very bottom, (closest to the home-button).
It is strange!... I tried disconnecting and then reconnecting the LCD (and 2 other nearby) cables. No luck: same problem still remains.
Tried doing a hard reboot. Still the same problem.
MORE DETAILs:
When it powers on, (the apple logo seen on the screen), these horizontal lines are (strangely) only about the width of the home button — right above the home button, furthermore — and, they are white.
After the power-on cycle is completed, the lines become black, and spread horizontally across the entire screen — but, only a few of them, all towards the bottom.
On the home screen, there appears to be only two black lines. If I open an app — any app — then there are three. (Weird!)... — Or, if the home-screen seems to only have two, then it might be said that the third one is 'partially' or 'faintly' there. However, it becomes more 'clear,' in opening any app, (if that makes sense).
Have three photos; I uploaded them to a Google account, to share them, here:
(3 photos showing the horizontal lines at the bottom) — [yes, I have a black home-button on a white screen... I'll have to get used to it!...lol]...
Any ideas?... Any help?...
I can live with this — it's not "life or death." But, if there's something obvious that I am missing, then it'd be nice to know something else to try.
Thus, any help is much appreciated. Thanks, in advance.
iPhone 5s LCD及数字转换器图片
指南
难度:
中等
30 minutes - 1 hour
iPhone 5s 显示屏图片
指南
iPhone 5s 显示屏更换
难度:
中等
30 minutes - 1 hour
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I would see how the screen looks before clicking it into the housing of the phone just in case those lines are caused by anything putting pressure on the rear of the screen. If that doesn't help anything, try a new screen, it could just be that you have done everything correctly but unfortunately had a faulty part.
这个答案有帮助吗?
得分 0
4条评论:
Good suggestion.
However, I wonder if I might have already tried it, (somewhat): for, I had left the housing separate from the screen, powered it on (all cables connected, obviously); but then, (with the phone not yet closed again), the problem still showed up.
On the other hand: I wonder if maybe I connected those home-button screws a little bit too tightly?... — or, if maybe the parts aren't seated properly... (e.g.) —
Could that be the cause?...
I'll try taking another look later on, if nobody suggests anything else in the meantime, after awhile.
Thanks! :)
P.S. Just edited original posting, to link to 3 photos, (if interested or helpful or relevant):
https://goo.gl/photos/VQuy5cyj7Tk7W2HRA
完成的
The screen is faulty. The only way you are going to get it working again is either replace the screen or try straightening the display ribbon cables without damaging it.
完成的
"...try straightening the display ribbon cables..."
—> Not quite sure what I'd be attempting to try straightening, on the cables. Anything special, here?
There appears to be a "seam" or some sort of "splice" in the cable, (with even a little bit of copper still exposed, along with a small bit of overhanging, black electrical tape!... seems cheaply made, perhaps?...)
I'll eventually try it; any pointers or tips about this, much appreciated.
完成的
Just the black part of the screen ribbon cables only where it usually gets bent / folded.
完成的
添加一条评论
Quick follow-up: the seller won't respond to me (for a refund/replacement part), because too much time has passed (since April purchase on eBay) and they can't find any record on their eBay account, anymore... (Weird!?)
@Ben: I reopened it and tried straightening the display ribbon cables; result = no success.
The problem is not so bad that I can't live with it. If I decide to shell out another $20 bucks, (and another hour of time to do the repair), I might later see if a new part fixes the problem. If so, I'll update this later, for the sake of posterity — if it should help anyone in the future.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
at0gjm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,791
