跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Unable to activate Touch ID after housing replacement
Hi,
one day ago I replaced my used and damaged IPhone 6 Housing with a new one (not a used one; Bought a new one from ebay in matte Black and Gold). So far so good, but after i reassembled everything, my Touch ID wasn´t working correctly, so did a reboot and i did a soft reset with the hardware keys. After this I got the Message, that it`s "Unable to activate Touch ID".
I also changed the ribbon cable on the back of the metal plate on the Display and tested the old one with another IPhone (it worked)...
I am really confused now, since i didn`t touched the Home Button at all (no need when you don`t change the Display...)
Any recommendations?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Did you simply change the metal housing, or did you change any of the internal parts (like the logicboard)? Since each home button is paired to the logicboard, replacing either the home button or logicboard will disable Touch ID. If you are still using the original logicboard and home button that are correctly paired, it is possible that you damaged the home button cable.
这个答案有帮助吗?
得分 0
1条评论:
Yes you have to remember that the home button with same phone only works not other.Maxium chances is that the home buttom flex is damage or on home buttom clearly check out there is on crystal ic try to clean with.
完成的
添加一条评论
Try resetting all settings.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 607
