跳转到主内容
Released in 2013, the IdeaPad U430 Touch, Model #20270, is a streamlined 14" Touchscreen Ultrabook by Lenovo. You can find the Device information and Model number on the bottom of the case.
6 个问题 查看全部
Is it possible to replace the keyboard of Lenovo IdeaPad U430 Touch
Is it possible to replace the keyboard of Lenovo IdeaPad U430 Touch laptop?
It looks like is soldering with the base.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@spiroan Looks like you are right...can't be removed on that model...
Best price I found is China delivery on ebay
这个答案有帮助吗?
得分 1
1条评论:
Its the Lenovo IdeaPad U430 Touch Model Name: 20270
This one---> https://www.amazon.com/Lenovo-IdeaPad-U4...
完成的
添加一条评论
Yes it is possible, but it requires a very good “technical" repair skill.
My kid spilled a glass of water over his U430/i5 and after drying it for a few days, and checking inside, many keys had stopped working. I had to buy a new keyboard, and at that time, I only found it in a store in Japan. They did not have any instructions on how to proceed for the replacement (ie just wished me good luck).
So what I engineered for this fix was this:
Start by downloading the maintenance manual/guide from Lenovo (or the web) to disassemble the laptop (and disconnect battery - no power please!), and use a clean (static free) place to do this, and keep track of all screws and (or take pictures each step of the way) or you will end up with lots of spare parts and a bad device.
1) you will see that the keyboard uses plastic rivets (looks like white dots) to fix the keyboard to the chassis,
2) so I needed to “cut” each rivet (heads) of them with a stiletto blade (and they are many!), to be able to release the keyboard.
3) Exchange the keyboards, and then you will need a soldering iron to reattach the keyboard again, melting each rivet head (remember, they are many!), one at a time, resembling the original fixture.
I took me about 3 hours of non stop work (from 9PM to mid night) to finish and be able to boot laptop again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
spiros 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 1,483
