跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
Power Button Wiring Mac Mini 2011
Got a Mac Mini in for the fan connector replacement which has been replaced, however the wires going into the power button from the logic board have been pulled off by the customer when fitting the dual hard drive enclosure.
I'd like to strip and resolder the wires to the power button PCB, but could anyone confirm which wire goes where (black and a grey one), since I haven't got another one to hand, and it's possible they are in the wrong position.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I don't think it matters, which goes on what side.
Double check using a Ohm meter to see if one side of the button contacts is chassis ground, if neither are it makes no difference.
这个答案有帮助吗?
得分 2
3条评论:
Thanks, I'll check once I'm in again on Saturday. I'm sure it said something like 'PWR1' and 'PWR2', but I only saw this when I peeled back the tape to see the wires were damaged, so I'm probably wrong
完成的
Its a soft switch - Momentarily contact blister switch, which is sensed within the power supply to kick the power supply on. Just like the iMac's
完成的
Thanks. Grey wire (gnd) goes on the left side and the black wire on the right side. Works fine now :)
完成的
添加一条评论
添加你的答案
Reece 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,109
