跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Won't turn on unless
Hi guys,
I have a Apple MacBook Pro "Core i5" 2.5 13" Mid-2012
The problem with it is it won't turn on or off by the power button.
Symptoms are:
  • It will only come on if I disconnect the battery and adapter and hold down the power button for a few seconds reconnect the battery and plug in the adapter, then it will start automatically.
  • It will start if you then restart it. On the desk top.
  • If you try to start it with the battery disconnected, you get the continuous three beep noise indicating bad ram connections (it has frozen before, crashed and gone to this state)
Once the battery is completely charged it won't start at all.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
完成的
添加一条评论
1个答案
最有帮助的答案
Your symptoms imply the logic board has problems. Did you have a liquid spill at some point into the system or sit it down on a wet surface?
I think you'll need to open the system up and do a full inspection of the logic board for any damage. Follow this IFIXIT guide: MacBook Pro 13" Unibody Mid 2012 Logic Board Replacement you should only need to go to step19. If you see any corrosion, staining, discoloration or burnt parts take some detailed pictures and post them here for us to see.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nigel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 61
