跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Why i'm getting the screen like the photos atached?
So i bought a iPhone 5s screen to replace a broken iPhone SE screen, the thing is everything work's fine until after some minutes of working the screen shows colored vertical bars and white screen and backs to normal after some time.
See the pictures below:
Photo 1
Photo 2
Photo 3
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
The most logical explanation is that you have a poor quality replacement screen. Where did you buy it?
If it came from a reputable supplier like iFixit, then I would contact their customer service and ask for it to be replaced under warranty. If you bought it through eBay, you also have some recourse but know that the most, if not all, of the worst quality screens on the market get sold through eBay. That doesn't mean there aren't any good ones, just that you have a higher likelihood of getting a bad one. Also, some of the earlier and cheaper 5S screens don't work well on the SE.
There is of course a possibility that your logic board is causing the issue. I would try to re-install the original, cracked screen to see if the problem goes away or not. You can find a good dis-assembly guide here.
这个答案有帮助吗?
得分 3
2条评论:
Thanks a lot for the answer . I already took the iPhone to the store that sells me the display. They will see if the problem it's really the display and fix him in case of.
完成的
Glad to help.
完成的
添加一条评论
To clarify on why this happens. This is due to some aftermarket 5s screens still using the old copy display technology.
The good quality newer 5s aftermarket screens do not have this issue. But they are hard to find for SE unless you get the right supplier.
You can also get aftermarket SE screens to make sure you get one without this issue.
Alternatively you could use OEM SE or an original SE screen.
这个答案有帮助吗?
得分 1
添加一条评论
only 5S Original lcd working Good with SE. Copy 5s Lcd Not Working With SE.... Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
julioficabem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 105
