跳转到主内容
Why FAN ERROR on my screen
when turn on its appear on the screen FAN ERROR then a few sec..automatically turn off
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
i did all the youtube video,they have same problem...non of it work
完成的
添加一条评论
2个答案
已选择的解决方案
Hi @hukimoko, how long has you been using this computer? when you on, do you hear any fan sound?
1. some possible problems, fan bearing has worn out, oiling helps, but issues will surface again, perhaps to look for replacement parts in ebay or aliexpress.
2. check for any dust in the fan blades as it might obstruct the fan movement, causing low RPM values.
3. on rare cases, is the rpm sensor on the mainboard is having issues.
the system has been designed to shut the computer down when there is a fan error during POST, preventing damage to your laptop.
这个答案有帮助吗?
得分 1
添加一条评论
Possibly dust in Fan as after blowing it worked.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
LaKe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 17,448
