跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
replaced LCD screen, phone went dead. turned on several days later
So, I replaced my cracked lcd screen, which I have done plenty of times, and when I tried powering the phone on, it wouldn't. The battery was fully charged at the time. I replaced the new lcd screen and put the cracked one back again, still dead. I don't believe it was the new replacement screen since I connected the cracked screen and still had same problem. Anyways, Three days later I tried turning it on again and surprise! It works back again. Has anyone experienced this problem before? Or know what could have caused it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Its possible that you caused a non-fatal short when plugging in the new screen. I have seen a short prevent the display from functioning even when replugged, and the device power cycled. The 2 ways I've seen devices restored to full functionality was a soft reset or a full cycling of the battery itself (drained to zero then charged until boot).
Of course this only applies if you (one of the following) left the phone on/the battery plugged in/were not properly grounded when performing the repair.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabby 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 45
