跳转到主内容
A Bluetooth smart speaker by Amazon, announced November 6, 2014. The Amazon Echo SK705DI features a voice-activated cloud-based assistant that can manage various tasks including playing music, reading news, creating lists, and answering questions.
44 个问题 查看全部
Echo Acting like an 80s robot that is misfiring
My Echo is out of warrantee and recently she has been very strange. She frequently doesn't respond to my voice commands and then shuts down and/or says she lost internet connection, which is fine with other devices. Could it be steam from shower (which is low as I keep door open in bathroom when shower is being used) or something else? She is acting like a misfiring robot from an 80s sitcom at times. I'm not sure what to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
it could absolutely be steam.
Sodium and calcium buildup are some of the minerals involved in corrosion, which is also known as water damage. Steam can easily cause problems in a device. Short circuits, are the end result of it.
There could also be software corruption, Antenna failure, or Microphone issues.
这个答案有帮助吗?
得分 0
添加一条评论
If your Alexa is not responding or working to your voice commands then perform basic troubleshooting to follow some points:
  • Check for Microphone
  • Restart your device
  • Hard reset your device if not restart or reboot option not work,
  • Enable/Disable Alexa privacy
If above mentioned steps not help to fix Alexa '''echo does not respond''' '' then check outs some points such as
  • Always keep the device 20 cm away from the walls, as dust from the walls can get onto the speakers thus, obstructing the voice path to reach Alexa.
  • Also, make sure- there's no loud noise when you speak.
  • Other than this, make sure while you give a voice command to Alexa, your voice is clear and natural.
  • Last but not least, keep your Echo device away from all machines with vocal outputs, for example- TV, radios, microwave, and many more.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lisa and Fenway Hazen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 87
