跳转到主内容
加入维修社区 - 创建账户
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
Screen Won't come on after digitizer repair
Hey guys I was replacing the digitizer on my iPad 2 the other day and the lcd won't turn on. I haven't sealed it up yet but I have tried to force reset it and it didn't work. But when I plug it in I hear sounds. But also the screw that holds the battery connections to the logic board is stripped. So guys please help if you can
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Also the iPad was on when I connected the LCD
完成的
添加一条评论
1个答案
Assuming your Home and Power buttons were both connected on the circuit whilst you did the hard reset, (Home adnd power for 20Sec),
take a flahs light to the screen and see if there is an image on it, without the backlight.
If this is the case, likely the backlight filter, or diode has blown. This is the most common failure for home repairs next to physical damage. Ususally caused by doing the repair while the device is on. this is a microsolder surface mount job. if you are comfortable with SMT repairs, then here
http://www.cyberdocllc.com/shop/full-rep...
这个答案有帮助吗?
得分 0
3条评论:
What is the best way to tell if the home button is connected
完成的
Does the home button just connect to the two gold posts on top of the charger
完成的
yes. the button traces on the component itself pressure connects to the gold posts on the Charge Flex
完成的
添加一条评论
添加你的答案
Thomas Covert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 67
