跳转到主内容
The Xperia Z1 Compact is Sony's premium camera phone. It is similar to the Xperia Z1 model except smaller and less expensive. Its key feature is a 20.7 megapixel sensor. Upon release the available colors were white, black, pink, and lime. This device can be identified using the model number (D5503)
Jumping menus and text after screen replaced
Having replaced my screen there are faint white vertical bands on the display. I can live with that, but text and menus jump about; the touch screen function stops working too. Is it motherboard or screen problem?
the problem seems intermittent, so immediately after replacing the screen, no problem, but wait 5 minutes and the faults appear.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
It looks like a defect screen, especially due to the vertical lines. In most cases if the board really was damaged the touch or screen isn't working completely, but not sporadically only. This sounds more like a typical issue of a bad manufactured and cheap replacement screen.
Try to reseat the cable, double-check if they are sitting correctly and try again. If it is still failing you should return it as defect and ask for a new one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 261
