跳转到主内容
This tablet is 9.09" high, 6.21" wide, 0.34" thin, and was released on October 2nd, 2011. Its Model Number is GT-P7310.
7 个问题 查看全部
Why is my Tab not coming ON?
hello, I have a tab 8.9 4G p7320T which does not power ON.
I was trying to enable gsm voice call on it. So I first of all flash CWM recovery so that I could install the necessary zips to enable the call system. After flashing CWM, I now copy the zip files to a folder I created in the internal memory since the tablet doesn't take sd card. I successfully install the zip files but forgot to wipe cache and dalvik cache and went straight to restart. Since then till now it's not powering on, not entering into recovery mode, not entering into the downloading mode or showing sign of charging when the charger is plugged.
Also, when I plug the usb cable to my computer, it say format disk,
Pls what can I do to restore my TAB
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
try disconnecting the battery and leave it unplugged for five minutes or so . this will wipe the cache and give you a fresh boot
Samsung Galaxy Tab 8.9 Battery Replacement
This guide will show how to open and locate the battery connectors . You don't need to remove the battery just disconnect it . that said you also do not need to remove the video cables in steps 5 6 and 7 so skip straight to step 8 once you have your tablet open . Hope this helps
这个答案有帮助吗?
得分 2
1条评论:
Its not still coming on
完成的
添加一条评论
添加你的答案
Nyimeh Gweh Gerald 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 257
