跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Voice Memo Microphone not working
Customer has brought in a device. The customers Voice Memo or snapchat if you attempt to record is just crackly. We have tried a Front Camera Flex & Powerflex (with rearmic built in) and still no sound. New earspeaker mesh also. Any suggestions please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Were you able to fix this? I have the same problem.
完成的
添加一条评论
3个答案
已选择的解决方案
There are 3 microphones in the iPhone.
https://support.apple.com/en-us/HT203792
  • The bottom microphone is for Voice Memo and phone calls. The other microphones serve as error cancellation
  • The (top) front microphone is used for FaceTime calls, Siri and selfie videos with the front camera (FCAM). The top back microphone serves as error cancellation
  • The (top) back microphone is used for videos with the rear camera (RCAM). The top front microphone serves as error cancellation
Make sure you update your device to the latest version of iOS and then try to isolate which microphone is not working properly by trying each individual microphone with the related apps above. If the issue affects more than one microphone, then it could be the Audio Codec IC on the logic board.
Anything at the logic board level will require micro-soldering so you would need to find a repair shop that offers those services.
这个答案有帮助吗?
得分 2
1条评论:
I have the exact same problem, and this solution is not really a good one as calls work fine but the voice memo app does not.
完成的
添加一条评论
最有帮助的答案
i dont think this is an hardware issue.
iam on ios 11.4.1 iphone 6s
  • memo and 3rd party memo recorder r - just static sound
  • phone calls on speaker -fine
  • phone calls normal - fine
  • front cam - fine
  • backcam - fine
so the one and only thing not working is anything that ask for acess to microphone which is wierd.
这个答案有帮助吗?
得分 3
2条评论:
I have the same problem except that phone calls fade out , i think it’s software because many users reported that they replace the mic and didn’t solve the problem
完成的
I have the exact same symptoms as you. Not finding any joy so far. Have you figured this out?
完成的
添加一条评论
Hello! Seems like the microphone was damaged. Have you tried to replace it?
这个答案有帮助吗?
得分 0
1条评论:
I have replaced the microphone flex at the bottom but it didn't help. The front and back video records the audio just fine. Sometimes the audio over a phone call also sounds like it's static. Have messed around wih the software to determine it's not a software related issue.
完成的
添加一条评论
添加你的答案
Phone Repairz NE LTD 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 25
总计 25,987
