跳转到主内容
加入维修社区 - 创建账户
Smart fitness watch via Bluetooth, released in March 2016. Model: FB502SBUL
Heart Rate Monitor Cracked
Has anyone experienced a cracked HR monitor? I'm specifically speaking about the little area between the green flashing LED's on the back of the Fitbit blaze. Wondering if this is contributing to the screen not waking on command, home button being unresponsive, and overall less than seamless working experience.
Bigger question, can it be repaired?
Thank you!
Jax
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If you are just aiming to fix the heart rate monitor, then yeah thats possible, just use the guide for the replacement motherboard up through step #6 and the try to source a replacement back housing/heart rate sensor for the device. If you are not able to find it, try looking for a Fitbit blaze that has a cracked screen or that won't turn on because odds are that unless the back glass is cracked, they are usually pretty good so unless you can't find a replacement sensor, your best bet is trying to find a really broken and cheap example with an alright looking back.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jackie Mazzola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,277
