跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 个问题 查看全部
iPad mini 1 slowly battery drain
I have an issue with my iPad mini 1: slowly battery drain (1% in 1 Hour). When the iPad on or off it is the same percentage battery drain. Without digitizer and screen is the same percentage battery drain. There is a Short in PCB but I don't know where. No Chip getting hot (maybe not hot enough to detect).
I turned off the iPad and I connect the battery connector to Power Supply the current goes to 0.05A and after 2 or 3 Seconds goes to 0A and then goes back to 0.05A and so on.
Please, can someone advise me where can I find the short?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
could be U2-chip Issue ?
完成的
添加一条评论
1个答案
Try turning off the wifi and bluetooth and see if you still have the same issue. Also try it with it completely off. (hold power button and hit the slider.)
这个答案有帮助吗?
得分 0
2条评论:
already done and the same issue.
完成的
Sorry, I don't know enough about the chips to say. But there are others here who are familiar with replacing the chips.
完成的
添加一条评论
添加你的答案
Med 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 111
