poor wifi and bluetooth signal after screen replacement
hello,
after a screen replacement with a refurbished one, now i have poor wifi and bluetooth signal on my lg g5. i suspect an antenna issue. someone know what could be the matter?
yup sounds like the antenna. order a replacement and swap it over.. if this doesn't fix it, will most likely be a logic board issue. 90% of all cases on the device is the antenna.
furthermore make sure you reseat the antenna connection.
这个答案有帮助吗?
hello, thank you for your kind reply. Do you know where can i find the wifi/BT antenna in the logic board?
8 minutes ago by Gabriele Filoni
I had exactly the same issue. Check the antenna cable, it is under the motherboard, one of the connectors was disconnected, in my case and that solved the problem. Probably, when I was replacing the screen I accidentally disconnected the cable.
这个答案有帮助吗?
Thank you very much it works!
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 50
总计 1,312
2条评论
由 Gabriele Filoni 完成的
Hello
I have the same problem, did you find a solution?
由 Camera5 Amazon 完成的
