跳转到主内容
加入维修社区 - 创建账户
Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
Touch Screen Not Working
hey .
I got ipad pro 9.7" which felldown on the floor and touch screen stop working ..it is not even broken i do restart by power button nd home button still nothing , now i open the ipad put new lcd reconnect the battery ,,,,but nothing ...
Can u plz help me???
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Is your iPad recognized by an iTunes enabled computer when you connect it? If it is, it means the the iPad is working but not displaying an image on the screen. You could try to shine a bright flashlight on the screen to see if there is a dim image. If this is the case, then you either have a damaged screen or a damaged backlight circuit on the logic board.
If the iPad is not recognized by iTunes, then you have a logic board issue.
If you believe the screen is at cause, you find one here. As for guides, there are only partially completed guides for now. The problem with the iPad Pro series is that parts are very expensive and that makes troubleshooting it yourself not worthwhile. I would take it to a reputable shop, preferably one that has parts in stock for this model. They will be able to isolate the issue properly.
Replace a LCD Screen and digitizer compatible with the A1673 and A1674 model iPad Pro 9.7". 2048 x 1536 (264 ppi).图片
产品
iPad Pro 9.7" Screen
$179.99
这个答案有帮助吗?
得分 1
1条评论:
They said the touchscreen doesn't work as in the touch part as in it doesn't recognise touch. Same thing happened to me. This answer isn't helpful because you think the display isn't desplaying.
完成的
添加一条评论
添加你的答案
Zahid Mehmood 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 2,680
