跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
问题已关闭
iPod touch slammed on table, now unresponsive
My son slammed his ipod touch down on a table, backplate first last night. It now will not turn on or charge or anything. He said the screen briefly turned white. It was plugged in all night to a wall charger to no avail. The screen does not appear to be cracked, and I cannot hear the audible click that indicates it's charging. Any suggestions would be greatly appreciated!
Update:
When plugged into a computer, it shows up in iTunes and allows me to see everything on it. Any ideas??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
So, do you try to restore it? (make a backup before because by restoring your iPod, you will lose all data in it).
这个答案有帮助吗?
得分 0
添加一条评论
Sheatwole03,
If the restore doesn't work then the LCD could have either come unplugged or been damaged by the shock. Find a seller that takes returns, purchase an OEM LCD and go through the display replacement guide to install it. Also let us know how you do so we can all learn from it.
这个答案有帮助吗?
得分 0
添加一条评论
I successfully restored it, but it did not fix the problem. After disassembling the iPod, I noticed a very thin crack running horizontally across the screen. I'm not sure why this would cause it not to display (as is the case with spidercracks, often times) but I will go ahead and replace the screen and see what happens. Thanks for the suggestions!
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,797
