跳转到主内容
加入维修社区 - 创建账户
于 2013 年 5 月发布。显示屏 - 1200 x 1920 像素,10.1 英寸。芯片组 - Qualcomm Snapdragon APQ8064, CPU - 四核 1.5 GHz Krait,GPU - Adreno 320。存储 - 16/32 GB,2 GB 运行内存。运行 Android 操作系统,v4.1.2 (Jelly Bean),可升级至 v4.4.2 (KitKat)。
steps to reboot after replacing battery
battery replaced but tablet will not reboot. after charging LED blinks three times. what are steps to reboot?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
How long have you kept it on charge? In some cases some batteries are dead flat and take a long time to even just show the charging logo on screen.
这个答案有帮助吗?
得分 4
1条评论:
Thanks for the insight. I went ahead and ordered a SONY charger/cable. The battery is a new SONY replacement battery just installed by a tech. The tech advised that sometimes using some other cable results in not charging correctly. Since I was using some other cable the battery LED indicator never changed from red. In my attempt to reboot the tablet the LED blinked 3 times. I thought there was some trick to rebooting the tablet after installing a new battery. I'll charge the tablet using the OEM and hope to get the green light.
完成的
添加一条评论
添加你的答案
Carlos Gonzalez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 363
