跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Screen had white shadows after replacement
Hello. I got my screen replaced at Timpsons, but then realised that there are some white shadowing at the left bottom corner and on the side (more visible when the screen/photo is dark in that place), when the screen is white i can see like some greyish shadows all over the screen. I gave the phone back to them twice to fix it, but they say that everything is fine and didnt fix it. Any ideas what is wrong with it? Is is a fake screen on or did they damaged it while replacing it?
Thanks
Update (08/09/2017)
that should be a photo in the dark, so you can easily see all the white shadows... please help!! ☹️
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
It looks to me like a low quality replacement screen, specifically the backlight. There is also a coloured bar on the left which doesn't look right.
I would go back to the shop and insist for a proper repair or reimbursement (by installing your original screen - then looking for a reputable shop that stands behind their repairs).
这个答案有帮助吗?
得分 2
3条评论:
That coloured bar on the left is from the screen protector that they put on not really in the right place, cause it's like not actually covering 1mm of the actual screen if you know what I mean. After trying to fix it twice I asked for a full refund, but i got only half price. I am trying to deal with customer service but don't know if they will help :/
完成的
I guess that's a lesson learned...sadly.
完成的
Agree with Mino, but if they don't help and it bothers you, just save it as a backup future emergency screen and buy another... screen cost are as low as $25 to $30 and up. I've purchased good acceptable quality screens off Amazon for $26 for 6s for customers that had to save $ and they worked great with a 30 day money back guarantee.
完成的
添加一条评论
Backlight problem. Faulty screen and/or they damaged your motherboard lcd connector.
这个答案有帮助吗?
得分 1
1条评论:
I agree with what sheep said, but I've also seen this problem occur when there is frame damage which is highly unlikely but something else to check. See if the shadows are still there when the screen is just placed on the top of the phone, not snapped in . If they are I'd try a new screen, if that doesn't work then the LCD connector on the logicboard is probably damaged.
完成的
添加一条评论
The problem with aftermarket copy screens is there inability to have a bright backlight. Check out this post on how to spot a fake iPhone screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kristina P. 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 30
总计 4,496
