跳转到主内容
Can I include a fuse in the generic USB car charger?
Bought a generic USB car charger. Can I just purchase one and include it in the charger? If so what amperage?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I originally had the pink one which came with a fuse similar to what is pictured. However the fuse was lost because the tip of the charger was removed and it popped out. I bought the white one which came without a fuse. My question is what amperage fuse should I get to replace the lost fuse? The second question was if I could add a fuse to the white one as a safety measure,bearing in mind the fuse is simply inserted into the top of the charger.
[image|1173438]
[image|1173436]
[image|1173435]
完成的
添加一条评论
1个答案
已选择的解决方案
The car charger was either designed to take a fuse or it was not.
If it isn't, you can't easily add one unless you take it all apart and modify it yourself (if it is even possible at all).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kevin Thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 471
