跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
ear speaker not working normaly
Hello all!
A customer came in with her phone because the ear speaker was not working normally. You can hear something but its very very low sound. Even the sound is full up.
I have tried the following.
  • Replacing the ear speaker iFixit Ear Speaker
  • Replacing the front camera and sensor cable iFixit Front Camera and Sensor Cable
  • Replaced the whole screen.
  • cleaned the phone with alchohol.
  • resetting the phone to factory settings.
  • used 3utools to flash the firmware.
  • tried recovery mode with itunes
All this without luck. Any of you out there have any idea or solution?
Thanks in advance :D
Replace an earpiece speaker compatible with the iPhone 6 model #A1549, A1586, A1589. Fix problems with phone call audio.图片
产品
iPhone 6 Earpiece Speaker
$16.99
Replace a front camera and sensor cable compatible with the iPhone 6. Includes the front-facing camera, secondary microphone, ambient light and proximity sensors. Part #821-2172.图片
产品
iPhone 6 Front Camera and Sensor Cable
$30.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
It sounds like you have covered most everything I could have thought of. Have you tried removing the micro screen that the speaker sits in to make sure there is no foreign particles blocking the sound from passing through? Also, is there any other mic, headphone jack, speakerphone issues (Just thinking audio IC).
@captaintech
Only other thing I can think of is the FPC Connector damage or possibly a filter or cap is bad?
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your answer. yes we checked where the speaker sits and as i mentioned even tried a new screen. We cleaned all the parts of the phone related to this. The phone has no other issues then the ear speaker. The loudspeaker and all mic's works perfectly. I am thinking there must be some sort of issue on the motehrboard but i am not sure of why or where.
完成的
添加一条评论
Maybe checking the battery’s connections? I had an audio issue that appeared after I changed batteries, but never managed to fix it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Total Repairs AS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 4,092
