If my U2 IC Chip is broken, does charging the phone damage it more?
Does charging the phone while having a broken u2ic chip make the problem worse?
I am surprised that it would still power on with a "Broken" U2 IC. Is it physically broken or do you just think it may be? What are the symptoms you are having>
这个答案有帮助吗?
Battery draining after it charges, random battery drain with a new battery
to eliminate the charging circuit you should use a multi meter to measure for charging voltage at battery connector...but sounds like either bad battery, charging port or Tigress/or U2.
Here is a link for testing:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 6,071
