跳转到主内容
Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
66 个问题 查看全部
Sudden shut down and not able to switch it on
I was using my oneplus 3 and it randomly shut off. It wont respond to anything. Battery charged 90% enough for 10hrs . Tried pressing power button and volume down buttons same time, for factory reset it wont respond. I faced no such issue earlier. Everything was fine till now. Please advise.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Wait till next day for the battery to drain completely .then charge again.
完成的
I kept my phone in fridge for 20-25 min. then tried to plug in to dash charger n started pressing on/ off button several times and tried plugging unplugging cable while pressing on/off button n mobile got switched on
完成的
添加一条评论
3个答案
最有帮助的答案
Mine does this. The way to fix it is press the ON button while plugging it it and keep it held down while you unplug it and then plug it back in again. That always fixes mine. Don't ask me what causes it to shut down in the first place though.
这个答案有帮助吗?
得分 7
7条评论:
OMG this really worked for me! I have no idea why, but it does!
I only registered for this website to say thank you and confirm this solution :)
完成的
Worked for me too. No idea how does it work. And yes I also signed up to say thanks :)
完成的
How its work anyone tell me.
完成的
I just signed up to thank you! You saved me a lot of trouble! I am eternally grateful to you!
完成的
Can confirm this works on a 3T as well. I don't know how you figured this out, but THANK YOU!
完成的
显示更多的2条评论
添加一条评论
I am using one plus 3 phone but it often switched off automatically . And when I gng to switch on some times it's not respond and some days 10-15 days working good and some days daily 10-15 times is going on switched off pls anyone give suggestions wat I will
这个答案有帮助吗?
得分 1
添加一条评论
Have you tried the unbrick guide from the OnePlus forum? It may be a software issue, and if so then the first method in the unbrick guide should solve it. :)
https://forums.oneplus.com/threads/guide...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
POTHUMUDIS 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 28
过去 30 天: 88
总计 10,782
