chromebook is connected to wifi but has no access to internet
I have a brand new Asus and can't even get it started. My wifi is connected and showing its on strong, but no access to any internet... I ran diagnostics and it says
captive portal "canceled"
DNS "failed"
Firewall "canceled"
google search "canceled"
Local network "canceled"
I don't know what a DNS is
So I did a "powerwash" and restarted it... again it says network not available when I am hooked up to my home wifi... (all other devices are working off the wifi just fine). When I click more it goes through process of trying to connect which I did 50 times already.
How do I know if I am using WEP, WPA/WPA2, EAP-TLS, EAP-TTLS, WAP-PEAP, or TKIP???
3条评论
Need more information about the wireless network you are connecting to, is it a WIFI router or a wireless access point? Does your chrome book connect to internet in a different location such as a coffee shop?
由 DrGlowire 完成的
did you ever figure out the problem, my son's Asus C101pa chromebook is doing the exactly the same thing. It started not connecting to the internet after it left and wouldn't reconnect. it is a new router and new service but this thing has always been flaky since we have had it. This is the second one the first one the charger quit after a week. Returned for a new one.
David G
由 David Glavich 完成的
I called Asus tech support because I've couldn't get it to work. I was instructed to forget the WiFi that it wouldn't connect powered the Chromebook off and turned it back on, signed in, logged into the home WiFi, entered the password and it logged in. I had done the same thing 10 times with out sitting it off and it worked.
The WiFi on that Chromebook is still kinda flaky. But it is working hopefully it gets better.
David G
由 David Glavich 完成的
