跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Won't power on - at all. What to do/replace?
School computer for student use was brought to me with complaint: running on battery-only, unexpectedly powered down. I charged with known-good outlet and power adapter for over 24 hrs. At first the magsafe light would alternate green-orange, later only a VERY dim green glow. Pressing the power button has no noticeable effect - no noise or light. I've reset the SMC numerous times; swapped the RAM around; tried with and without battery.
Condition: magsafe port is clean; some damage to the case - probably voiding Applecare - topcase is raised somewhat near IR receiver, bottom case has hairline crack near join of topcase to left of trackpad (damage appears old); power button is SLIGHTLY depressed (but has satisfying click feel when pressed).
From reading here, I'm guessing it may be the mag safe board or topcase - but I don't know which is more likely, or maybe something else.
Suggestions?
BTW, this site is awesome!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I replaced the MagSafe board and it's now working! Thank you.
完成的
添加一条评论
2个答案
已选择的解决方案
I'd go for a new MagSafe Board, as it doesn't work, even when plugged in and battery removed.
See here:
MacBook MagSafe DC-In Board
Cheers,
deSteini
MacBook MagSafe DC-In Board图片
产品
$19.99
这个答案有帮助吗?
得分 1
1条评论:
Thank you. I've ordered the DC-In board.
完成的
添加一条评论
Swap in a new battery and try that, if not, I'd think the mag safe board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David A 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,575
