跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
After screen replacement, screen gets hot
Hello,
after we replaced the screen of a i6+, the customer came back with the issue that it gets very hot under the frontflex.
The heat is actually coming from the flexcabel of the lcd screen.
We testet it with 3 other screens from different suppliers, changed different frontflexcables, cleaned everything completetly with isop and always the same problem.
Also if we start the phone with only the lcd connected it gets hot at this special point.
But connector self looks absolutly fine.
Maybe someone had already this kind of problem and knows something?
Any help would be very much appreciated.
Thanks and kind regards
Alex
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Has it had any water damage at all? if its not the LCD itself, the motherboard connector pins may be bad or the motherboard itself. Could also be draining all the power out of the battery if that was not replaced causing it to heat up everything..
这个答案有帮助吗?
得分 0
添加一条评论
Thanks for the reply,
no waterdamage and the connectorpins looks good.
The battery is also not the problem.
Any other solutions?
Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
I came across the same issue guys if you NOTICE THERES A 3M BLACK STRIP ON THE VERY FINE LEFT TOP OF MOTHERBOARD FOR IT NOT TO DO DIRECT CONTACT WITH LCD ASSEMBLY
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 3,157
