跳转到主内容
The production third generation Quest was unveiled for the 2004 model year at the 2003 North American International Auto Show.
8 个问题 查看全部
Temp rising slightly on highway and transmission slipping in city...
Temp rising slightly on highway and transmission slipping at stoplights in city afterwards. Changed trans fluid (was dark brown) - seemed to fix on test drive towing same camper - temp needle stayed pegged at normal. However, cooling fan turned on immediately when starting van 7 -10 minutes after test drive. Did trans fluid change possibly NOT fix the issue? -KJ
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
When towing with an Automatic, you should never be in the overdrive mode as this will kill your automatic. Did you drop the pan and replace the filter and pan gasket at the same time? If not then no you haven't fixed it.
完成的
添加一条评论
1个答案
Check your coolant level, transmission filter, your thermostat and water pump. Goodluck bud
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keith Jeronymo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 71
